Dabar yra 2026-10-12- 17:32
Naujos temos kūrimas Atsakyti į temą  [ 140 pranešimai(ų) ]  Eiti į 1, 2, 3, 4, 5 ... 10  Kitas
StandartinėParašytas: 2010-02-07- 21:53
to_mazas rašė:
Ale žiūrau brisos krautuvėj akcijų padavė :)
Ir nemažai: ;)
We are doing some special offers. More than 30 different products.
Free Brisa Catalog 2010 color print, with order if you write in the comment filed «  Free Catalog «
Knives
2028 EnZo Trapper SS Knife/Black Linen Micarta ..... 69 eur  (normal price 85 eur)
Knife blades
5807 EnZo Tundra 110 /D2 ....29,90 eur (normal 44 eur)
Grind: Full convex
5830 EnZo Badger 115 D2/Cv ..... 34,90 eur (49 eur)
Grind: Full convex
5509 Eklund Sandi  85   ... 23,90 eur (28 eur)
5432 Carlsson -75 ....29 eur (32 eur)
5408  Bergstrom Skinner 75     ...  17,90 eur (24 eur)
5370 AE Trapper Damascus/w Filework . 79 eur (99 eur)
5301 Mora laminated 82 .. 6,20 eur (7,80 eur)
Woods
6443 B Desert Ironwood Light  ... 27 eur (35,00 eur)
6443 A Desert Ironwood Dark.. 27 eur (35,00 eur)
6494 Thuya burl 9,90 eur .. (19 eur)
6355 Grenadil scalesx2 ..5,90 eur (9,90 eur)
6396 Striped ebony scalesx2 .. 6,90 eur ( 12 eur)
6381 Holm Oak scalesx2 .... 9,90 eur ( 16 eur)
6809 Stab amboyna burl ..19,90 eur (28  eur)
6849 Stab Spalted Oak .. 29,90 eur (34 eur)
6811 Stab Birch burl/black ..19,90 eur (32 eur)
6808 Stab Alder root/Natural ..19,90 eur (28 eur)
6803 Stab alder root/Royal Navy..21,90 eur ( 32 eur)
6501 Curly birch super ....4,90 eur ( 7 eur)
Materials
8300 PP red 0.8 mm....... 1,90 eur (3,40 eur)
8330 PP blue 0.8 mm .....1,90 eur (3,40 eur)
8222 G-10/Black-Green ... 3,90 eur (6 eur)
8469 MoP/Black lip (2-2.3 mm)/pair. 16,90 eur (29 eur)
4338 Swedish carbon steel UHB 20C/4x50x250mm ...3,90 eur (5,90 eur)
8528  Poly Abalone 6x40x110 mm      ... 3,90 eur (5 eur)
8525 Poly Oyster/White 6x40x110 mm  ...3,90 eur (5 eur)
8522  Poly Tortoise 6x40x115 mm .... 4,20 eur ( 6 eur)
8225 G-10/Jade  ..4,20 ( 6 eur)
1613 Buffer 90 .3,90 eur (6,90 eur)
1559  Sheath 95/Darkbrown/Hard   ...2 eur ( 10 eur)
- the sheaths are too hard for use. You can soften them in sodium bicarbonate and water.
Books :
4709 Knivmästarnas knivar/Samuel Karlsson  . 15 eur (20 eur)
All the well known Swedish Knife makers in text and pictures.
Discounts 30 - 60 %.
Also available Damasteel off cuts, low prices. Email for information
A few Enzo Trapper knives with very small cosmetic defects. Price 50 eur.  Email for information.
From our Online shop www.brisa.fi
Special offer expires until February 13  , or until the item is sold out.
 Pranešimo tema: Pakurti iš mano komentaro
StandartinėParašytas: 2010-02-08- 11:12
Pakurti iš mano komentaro atskirą temą gera mintis :) Manau dabar gera proga kombinuotis siuntą ;)
StandartinėParašytas: 2010-02-08- 13:49
Užsiregistravo: 2009-12-17- 12:24
Pranešimai: 45
Kas ruošiasi siųstis? Mielai prisijungčiau prie bendros siuntos.
 Pranešimo tema: Aha kas? As irgi tundros
StandartinėParašytas: 2010-02-08- 14:19
Aha kas? As irgi tundros gelezte priglausciau :)
 Pranešimo tema: Jungčiaus ir aš, kaip tik
StandartinėParašytas: 2010-02-08- 15:51
Jungčiaus ir aš, kaip tik ruošiausi keletą lapų Kydex'o ir spraudžių užsisakyt.
StandartinėParašytas: 2010-02-08- 19:58
Planuoju daryti užsakymą, tad parašykit man i PM kam ko reikia.
Geriausiai su tiesiogine nuoroda į konkretų daikta.
StandartinėParašytas: 2010-02-08- 20:35
Pranešimai: 45
Prikabinu paveiksliuką: "Also available Damasteel off cuts"
https://www.brisa.fi/offcuts.jpg
StandartinėParašytas: 2010-02-09- 16:06
Šis užsakymas suformuotas ir iškeliavo. :)
 Pranešimo tema: Siuntinys atvyko, bet dėja
StandartinėParašytas: 2010-02-13- 8:57
Siuntinys atvyko, bet dėja atsiimti galėsiu jau tik po švenčių, t.y. trečiadienį.
Linuks ir ek - jums į Kauną kaip geriau perduoti?
StandartinėParašytas: 2010-02-18- 9:57
Pats sostinėje būnu retokai, galėčiau prašyt ten dirbančių draugų/kolegų, kad paimtų prie progos.
Linai, ką pats mastai? Jei žadi būti Vilniuje, gal paimtum ir mano dalį? (Vis tiek ne už ilgo tau į akis lysiu, kai tik Spyderco Mule'ai atvažiuos :D)
 Pranešimo tema: tai prasom Vlado kad ir tavo
StandartinėParašytas: 2010-02-18- 16:30
tai prasom Vlado kad ir tavo dali palikyu musu ofiselyje, savaitas begyje kasnors davez iki kauno :)
StandartinėParašytas: 2010-02-18- 19:10
tai prasom Vlado kad ir tavo dali palikyu musu ofiselyje, ...
Palikau. :)
 Pranešimo tema: Dėkui Vladui už prekių
StandartinėParašytas: 2010-02-18- 20:29
Pranešimai: 45
Dėkui Vladui už prekių pristatymo organizavimą!
StandartinėParašytas: 2010-02-20- 15:31
Pranešimai: 137
Kada butu sekantis uzsakymas?
StandartinėParašytas: 2010-02-20- 20:16
Teoriškai įmanoma, kad kitą savaitę darysiu :) Bet čia dar nėra visiškai aišku
